Hi Chaps
Has anyone found a solution to this borrowing issue yet??
We have this problem on all our Windows 7, 64 bit machines.
I just tried to run the proe_borrow.bat as administrator and it's returning 2 error messages one in a DOS window reads
"x86e_win64_ptc_setvars' is not recognized as an internal or external command, operable program or batch file.
'ptc_setvars.bat' is not recognized as an internal or external command, operable program or batch file.
Could not find C:\PTC\WF3_M240\bin\ptc_setvars.bat"
The other in a windows error message reads Windows can not find '\bin\proe.exe'.
Any ideas / advice would be gratefully received.
TIA
I finally sorted it!
I generated a variable 'PRO_MACHINE_TYPE' and set it to X86E_WIN64
Then re-installed Pro-E and everything seemed to run fine, not sure if it was the variable or re-install that fixed it....
