WF4 Won't Start
bryan-3
2-Explorer
WF4 Won't Start
I use WF2 everyday with no issues and it had been a few months since I used WF4. I needed to use it because I had some models that I needed to reference. We I tried to start WF4, I got the hourglass, Xtop.exe shows up in the task manager for about 30 seconds, the hard drive is spinning away, but nothing.
I uninstalled and reinstalled with a newer build (M070). Still the same thing. The Std.out file has one line in it "Serious internal error; cannot continue." I have several users using WF4 with no issues. Any ideas? XP Pro SP2
Thanks in advance.
bryan-3
2-Explorer
(To:bryan-3)
We are not currently on maintenace so I do not have access to a later build of WF4. I did try to install on another pc that did not previously have wf4, with the same result.
In Reply to Pat Rogers:
Thanks in advance.
bryan-3
2-Explorer
(To:bryan-3)
Thanks all for the suggestions, got it to work.
The culprit wasa config.pro in the startup folder. It's not even the config.pro that I use. It was one with every single option listed.
Thanks in advance.
