WF4, M080When WF4, or maybe WF3, was released, you could drag a sketch with out going into redefine mode. It was quite easy to accidentally modify a sketch, so I turned it off via a config option, I think. Now, I'm in a situation where I think that would be handy and I can't remember what I did to disable it.I found 'sketcher_3D_drag no' in my config, but changing it to 'sketcher_3D_drag yes' didn't do it.How do I restore this functionality?Doug SchaeferThis thread is inactive and closed by the PTC Community Management Team. If you would like to provide a reply and re-open this thread, please notify the moderator and reference the thread. You may also use "Start a topic" button to ask a new question. Please be sure to include what version of the PTC product you are using so another community member knowledgeable about your version may be able to assist.
LinkedIn
