WF5 printing
mike_pavese
WF5 printing
Just migrated to WF5 from WF2, and printing in drawing on a HP Laserjet5100 using MS_Print_Mgr under the print dialog box, was fine in WF2 but in WF5 I can only see the geometry, all the dimensions and annotations are barely visible. Imagine the "line weights" need to be set in config.pro (didn't have anything in set WF2). Anyone know the solution?
TIA.
The line weights can be in config.pro, and/or pen table *.pnt file
Check for config.pro options in the <loadpoint>/text directory as well
as the normal places (start in directory, etc...)
Also note that some 'plot' options are locked/unlocked whether or not
you have full 'Foundation' or the converted 'Foundation Advantage'
seats.
Some options can only be set by using a 'Foundation' seat. (rotation,
for example)
According to our training source, printing and plotting was touched from
WF4>WF5 so expect some weirdness.
Christopher F. Gosnell
FPD Company
124 Hidden Valley Road
McMurray, PA 15317
