Calvin,
My impression was that Ilink 3.4 and WF3 would not run in Win7 so I installed Ilink 3.4 and WF3 on a Win7 laptopunder the "XP Mode" virtual machine. The Ilink 3.4seems to work normally but the WF3 is almost cripplingly slow even on a simple .prt file. And since XP Mode only supports 32-bit apps, I had to install 32-bit WF3 inXP Mode and thus am unable to take advantage of 64-bit computing power and RAM above 3GB.
Did you install the 32-bit or 64-bit WF3on your 64-bitWin7?
Up until a few months ago, we were using Ilink 3.4 with Wildfire 3 on Windows 7 (both 32 & 64 bit).
All worked as well as under Windows XP. However, there was one oddity.
The time stamp displayedin the Intralink 3.4 client (for object modified date/time) was always showing the internal (stored) time, which is GMT.
Being that we are in the easter tiem zone, the display was always 5 hours off.
So, the internal was correct, but was not displayed for the current time zone.
Gerry Champoux
Williams International
Walled Lake, MI
In Reply to Calvin Ying:
I know that Ilink3.4 (Currently at M020) is not supported on Windows 7. However, we are very desperate for an upgraded laptop and can't wait for our migration to pdmlink9.X
I have a Windows 7 machine which I have loaded the Ilink3.4 and WF3 and so far I am not seeing any issues yet. I only had 2 days (borrowed machine) to run some of the features so I'm not comfortable just go with it.
PC : HP 8760W Mobile Workstation
CPU : Intel i7-2640m 2.8Ghz 4MB Dual-Core CPU
OS : Microsoft Windows 7 Professional 64 OS
RAM : HP 8GB (2x4GB) DDR3-1333
DISPLAY : 1920 x 1080 (17.3 inch)
GRAPHICS CARD : NVIDIA Quadro 3000 2GB GDD5
HARD DRIVE : HP 750GB SATA 7200
DVD : HP 16X DVD+-RW SuperMulti SATA
If you have any issues or known problems with the above configurations please let me know.
Thank you all in advance!
Calvin
