@CT_10646942 wrote:
hi,this is Drawing mode
in Drawing mode click File > Prepare > Drawing Properties > Detail Options change and set lead_trail_zeros option according your needs.
I have settings in my config.pro file that might affect this type of behavior:
default_ang_units ang_deg
default_dec_places 3
minimum_angle_dimension 0.020
round_displayed_dim_values no
tol_display yes
You could try these, but be aware, to change them in an already existing part you need to explicitly edit the settings (File->Prepare) to change them for an existing model, or load the settings into your part.
In general to change a single dimension, you can select it then set the number of decimal places via the settings in the ribbon at the top of the window.
Thank you for your answer. My main idea is to eliminate the excess 0 after angle annotation. For example, in the following image, the right angle is 90 °, and I would like to label it as 90 ° instead of 90.00 °,and when it is not an integer angle, I still keep two significant digits. I have changed your configuration, but the angle display remains unchanged when re labeling...
is your question related to Part mode or to Drawing mode?
Thank you! It's already resolved!
