What is stable build code for Creo 3.0 to upgrade ?
ppandarkar-2
We are planning to upgrade Creo parametric from Creo2.0 to Creo3.0, so please can someone suggest any stable build code to upgrade.
Prashant
6 REPLIES 6
llie
(To:ppandarkar-2)
Prashant,
We have been running Creo 3 M070 for a while and have determined it was really stable. We are currently researching and testing M120 due to some enhancements and cabling and ecad  fixes.
ppandarkar-2
(To:llie)
Thanks for reply. please can you share review once tested M120. we are thinking for latest date code or 1-2 earlier.
Thanks once again.
-Prashant Pandarkar
Which can be found here.
Amit
Hi Amit,
Thanks for reply.
Actually, i mean to say which date code should we prefer like M100, M110, M120, should we go for latest M120 or it is better to select some 1-2 date code earlier.
if any industry upgraded latest M120 then we need its review, which can help us to take decision.
-Prashant Pandarkar
Are you having experience of using latest date code (M120) ? or know any industry migrated on latest date code successfully.
So we can think latest date code. Right now, we are testing for M120 but if we got some reviews then it will be helpful to us.
-Prashant Pandarkar
Have you looked at the Update Advisor? It is designed to help you answer this with specific information and allows you to evaluate issues based upon your actual situation, not (valuable but sporadic and questionable) opinions.
https://support.ptc.com/appserver/cs/update_advisor/update_advisor.jsp
