Michael,
Pro/Batch was replaced by Distributed Pro/Batch
Seperate install located on the Pro/e install disk. The server manager does not need to be install, only if you want to have the job run on multiple workstations.
http://www.ptc.com/WCMS/files/69139/en/Distributed_ProBATCH_RevI.pdf
Hope this helps,
Don Anderson
