My client are using Creo 9 with EMX 9.0 which has some configurations added on config file.
Now Creo is upgraded to Creo 10.0 and EMX 10.0 is also installed.
But when opened Creo 10.0 it shows error message of config settings file.
Need help what changes to be made for using EMX 10.0 with Creo 10.0
Rahul Sardar
Config option protkdat with value pointing to protkdat for EMX is the one which configures EMX with Creo. If it exists in your config you can remove that.
I think sharing some details about the options which will not work, can help understanding the issue better.
Thanks.
Hi @rahulsardar1,
Thank you for your question.
Your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Vivek N
Community Moderation Team.
Creo 10 has inbuilt EMX 16.0 which needs to check to include when installing Creo Parametric. If your customer has valid license for EMX simply include EMX in Creo 10 install and use. This process doesn't need any external configuration.
I hope this will help.
Thank you for the update Mr.Mahesh.
I am aware that Creo 10 installation is part of Installation setup.
But when i use the Creo 9 config file for Creo 10 , it gives message of few options won't work.
Need help to understand what changes needs to be made for use in Creo 10
Thanks.
Yes...protk.dat option is highlighting in the opening window. Will remove that.
Let me know if any other option is needed to be removed.
Thank you
Thank for the reply.
Now removed it and not getting any message
Hello @rahulsardar1,
It looks like you have a response from a support expert. If it helped to answer your question, please mark the reply as the Accepted Solution.
Vivek N.
