...I want the dialogue box to pop up and ask me if I want to append the file or open it in a new window. Creo 3 does this when I drag onto a part window, but not an assembly window. WF5 always asked. What's the config.pro option to always get the dialogue box?
set the following config.pro option
autoplace_single_comp no
Note: I tested it in Creo 2.0, only.
MH
MH
