Hello.
Our CREO License recently changed.
Current Situation is using Floating License and LMGRD.
Old Creo Licenses (Foundation, Parametric, etc.) changed CREO Essentials.
So, I have to change LMGRD's License Pack.
When I Change Creo License Pack, do I need to reconfigure CREO on all designer PCs?
if license name has been changed then you have to reconfigure CREO on all designer PCs.
Examples:
Creo Parametric (formerly Foundation XE) package
Creo Essentials package
Examples:
Hi, MartinHanak
Thank you for your answer.
My License's name changed. So it looks like I'll have to reconfigure every designer's PC.
@HK_10285495 wrote:
Hi, MartinHanak
if all installations are identical then you can modify Parametric\bin\parametric.psf file in Notepad on single computer and then simply copy this file to other computers.
The advantage of using a network install. You only have to make a single change and everyone has it.
