When there is a Creo license change, do I need to reconfigure CREO on all designer PCs?
HK_10285495
3-Newcomer
Hello.
Our CREO License recently changed.
Current Situation is using Floating License and LMGRD.
Old Creo Licenses (Foundation, Parametric, etc.) changed  CREO Essentials.
So, I have to change LMGRD's License Pack.
When I Change Creo License Pack, do I need to reconfigure CREO on all designer PCs?
if license name has been changed then you have to reconfigure CREO on all designer PCs.
Examples:
Creo Parametric (formerly Foundation XE) package
  • license name is PROE_FoundationAdv, also additional module 127 is used
Creo Essentials package
  • license name is PROE_EssentialsM
Martin Hanák
6 REPLIES 6
Examples:
Martin Hanák
Hi, MartinHanak
Thank you for your answer.
My License's name changed. So it looks like I'll have to reconfigure every designer's PC.
@HK_10285495 wrote:
Hi, MartinHanak
if all installations are identical then you can modify Parametric\bin\parametric.psf file in Notepad on single computer and then simply copy this file to other computers.
Martin Hanák
Thank you for your additional answer.
All Installations are identical.
Maybe this will work.
BenLoosli
23-Emerald II
(To:HK_10285495)
The advantage of using a network install. You only have to make a single change and everyone has it.
Thank you for your reply
I'll look into changing to online install.
