Where are common folders and favorites info saved. moving to new pc
creo 11
favorites are saved in web_favorites.xml file.
In my case (Creo 11.0.2.0, no Windchill connection) it is %PTC_WF_ROOT%\.Settings\web_favorites.xml file.
Hi @MTM,
Anurag
Thanks for Checking. I was looking to transfer my common folders and favorites found under file open in creo.
I did not have a web_favorites.xml file. I just recreated the common folders and favorites.
I did transfer my user interface custom settings including quick access toolbar by copying the creo_parametric_customization.ui file.
