Where do I find the "PTC Status" batch file in CREO2?
ptc-2053410
In all previous versions of Pro I have used you can find the "ptc status" batch file in the "bin" of your proe program files directory. I can't find this in Creo2, even better can you view it from the program yourself?
Are you checking the Parametric folder or the Common Files folder?
Here's the default installation path to ptcstatus batch file C:\Program Files\PTC\Creo 2.0\Parametric\bin
2 REPLIES 2
Yup you are right! Thanks Magnus.. I don't know how I missed it. Even did a windows search on the folder!
