Why can't PTC let the AAX modul float?
DareDevil
7-Bedrock
Why can't PTC let the AAX modul float? Now I have to buy more licenses and keep restarting the program...
Hi Daniel
You see this is several cases. Same when PTC changes from concurrent licenses for Intralink 3.x to named users for PdmLink. Well then say "We have lower the cost". - But in no way as must as the different between concurrent and named users.
13 REPLIES 13
As far as I know you can buy a floating AAX license but it costs significantly more. I may be mistaken but I believe this is the case.
AAX can float, tell me how old is your license.
Daniel,
AAX cannot float, because it is an eXtension. Only OPTION can float.
Extension must be attached to the main ProE license (for example PROE_FoundationAdv) during startup command configuration.
When user launches such startup command, the extension is automatically added to the main ProE license. User cannot disconnect the extension during ProE session.
Martin Hanak
Martin Hanák
Hmmm...
Well Daniel.. there's your answer. If Martin says it can't be done, I'd believe it. I was certain I've used a floating AAX before but I must have been mistaken. Before I posted I checked with one of my VAR contacts (value added reseller) and they told me they thought AAX was a floating module, too. Just goes to show you can't always trust salesmen to give you good information!
Martin,
How do I add that extension into my start-up command configuration?
Bob
Bob,
it depends on ProE (Creo Parametric) version ... What version do you use ?
Martin Hanak
Martin Hanák
Creo/Proe V5.0
Bob,
you can see brief information inside attached Word document.
Martin Hanak
Martin Hanák
Thanks Martin! That worked!
Best regards
Bob
Hi all and thanks for the replies
Ok, It is an extension and not an option, but why? Sorry for complaining, but I get the feeling that PTC is ripping me off.
Hi Daniel
if you only need to use the "Pro/Assembly" you can consider using the "Tool Design Option (Float)".
Note, TDO does not contain all of the AAX module
PTN-3101-F Creo Tool Design Option (TDO)
include : Pro/Assembly,Pro/SURFACE,Pro/DIEFACE,Pro/CASTING,Pro/MOLDESIGN-2
CPT-3021-L Creo Advanced Assembly Extension (AAX)
include : Pro/Notebook,Pro/Assembly,Pro/PROCESS_ASM,Pro/WEB.LINK
If what Sheng says is true, this is definitely the way to go. While Pro/PROCESS can be very useful for step-by-step assemblies, you're not losing much in Pro/NOTEBOOK.
