Why cannot assembly parameters be created directly on the drawing template file?
CT_10646942
6-Contributor
I am using Creo Parametric Release 9.0 and Datecode9.0.2.0
When I create an assembly parameter table on a drawing file, such as BOM, there is no & displayed before the parameters, and the table does not respond after importing the assembly. Assembly parameters only take effect when I create an assembly parameter table on the format file and create a drawing file using that format template. I would like to know how to directly create assembly parameters on the drawing file. Thank you.
in drawing mode & before the parameters is not displayed. Creo works this way.
I created test data and recorded video. Download it and use it.
Martin Hanák
please provide more details. Attach picture.
Martin Hanák
Thank you for being willing to help me
I imported a BOM table with defined parameters into the drawing file as a template, and then created a new assembly containing two parts, but the result did not display any information
I imported the BOM table with defined parameters into the format file as a template, and then created a new assembly containing two parts, displaying all the information
In the drawing file, there is no&before the parameters in the BOM table, but there is in the format file. I don't know why this is happening
Martin Hanák
It has been resolved. Thank you for your help.
