Why do PTC make things so hard?
GH_1172574
3-Newcomer
  • I have an old version of Wildfire 5 still running on a very old laptop. I would like to install the software on my new laptop as the oridgal laptop is on its last legs. But because I am no longer on maintenance this appears to be impossible. Login to my account then go to support and I am hit the same stone wall, you are not on maintenance. You cannot proceed bla bla bla. Is there a solution? Please help.
5 REPLIES 5
tbraxton
22-Sapphire I
(To:GH_1172574)
Assuming that you own a perpetual license for the WF5 installed on your computer then I believe that you are able to get a new license file assigned to a different CPU ID. If you bought this license from a VAR and not PTC directly then contact them for help.
Obviously if you are not able to log on the PTC support you would not be able to generate the new license via the web but if the VAR is not able to help you then call/write to PTC directly for assistance.
Involute Development, LLC
Consulting Engineers
Yes I own the perpetual license, The Vender I spend many years buying PTC products from closed down. In New Zealand there is no Vender. We are serviced by another country. I have no relationship with this company but will try and contact them.. Surely I am not the only person to have had this issue. Once a product is unsupported by PTC. PTC should send all customers a flexible license so they can move the software from old computer to new, regardless if that customers is on maintenance or not.
tbraxton
22-Sapphire I
(To:GH_1172574)
License Management can also be reached via email: wwlm@ptc.com. I would send them a detailed email explaining your situation.
You can use this URL for additional contact information.
Contact Licensing | PTC
Thanks for your help. First link failed as same message came up. Not no maintenance, move along sunshine. Lol
Second linked worked and have sent an email explaining the situation. Many thanks for your help. Have a great day.
Hello @GH_1172574
It looks like you have a response from a community champion. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
