Hello all,
Please somebody can explain or help me why Creo 2.0 is slow in showing a 2nd window?
2nd. windows pops up in +/- 15 sec. A 3rd, 4th... same situation.
My pc is running smooth and fast on other applications as IE, Office,...
What are your graphics quality setting set to? A lot of slow reaction times are a result of GPU cycles. Textures, line smoothing, shade quality... Reduce these and see if this helps.
What are your computer specs, specifically graphics card & driver?
The non-CAD graphcis cards typically fall short when you are openign multiple windows, although I've seen problems only when getting 4-5 or more.
Intel Core i7 cpu 980 @ 3.33GHz 3.33GHz - RAM 16 GB - 64 BIT
Nvidia Quadro 2000
Processor usage close to 0%
ha ha ha ha.....with that configuration i don't think its a computer issue.....
please log a support case to PTC technical support.....
Stefaan,
you can do a test - add the following option at the end of config.pro file to turn OPENGL graphics off.
graphics win32_gdi
Then try to reproduce the problem. If the problem disappears then you have to experiment with graphic drivers - i.e. try to find driver version "compatible" with CR2 M010.
Good luck
Martin Hanak
