I recently installed Creo 2.0. Installation seems to be successful. However, once I open a new Part, the planes and the coordinate system are not visible and I cannot start sketching. I uninstalled and re-installed Creo 2.0, but the problem remains. Any ideas? I need help!
Hi!
It turned out that I had a problem with my graphics director. I sent an email at the Support area and I received a very helpful reply with all the steps I had to follow. It is nothing to worry about!
Hi Evangelia,
Are the Datum Display Filters unchecked?
The problem is solved.
Thank you for your response anyway.
Hi, how did you solve the problem?
I am having that issue!
Hi!
