Wildfire 3 in openSuse 10.3
ptc-1502086
Hello, I trying to install Wildfire 3 in openSuse 10.3 to no avail. The answer I receive is this: sigtech:/media/Pro-Engineer Wildfire 3/dsrc/i486_linux/obj # ./ptcsetup ./ptcsetup: error while loading shared libraries: libXm.so.3: cannot open shared object file: No such file or directory Therefore I tried to install this library I receive this message: sigtech:/home/andreltr/Desktop # rpm -i openmotif-libs-2.2.3-11.i586.rpm o pacote openmotif-libs-2.3.0-23 (a more recent openmotif-libs-2.2.3-11) is already installed How to solve this please? Thank you. Sincerely, Andre Luiz
Hello, I was able to install a newer version of the library however I receive this message now: sigtech:/media/Pro-Engineer Wildfire 3 # ./setup ./setup: line 108: cd: /media/Pro-Engineer: File or directory not found ./setup: line 121: /media/Pro-Engineer: File or directory not found Starting PTC.Setup, please wait ... ERROR: /media/Pro-Engineer Wildfire 3/dsrc//obj/ptcsetup - file is missing. Check the name of the CD mount directory. How to solve this please? Thank you, Andre Luiz
Andre, The setup script maybe having trouble with the space in the directory name. Was it created that way? Carl Marcum
Hello, I was able to find the answer: the cd must not be labeled with a name that has spaces in it. A cd with no name works fine. I´d like to have an install guide for UN*X systems however because it is not easy to change the installation cds (I´m still trying...). Thank you, Andre Luiz
Andre, You might try opening "My Computer" and unmounting the drive from there. Carl
