Hi. I'm looking into buying a desktop and a lot of the ones I'm looking at install windows 7 premium. When looking at ptc platform support, it doesn't list windows 7 premium. Does this mean that I can't download pro/e? Does anyone here have windows 7 premium and that is also able to use pro/e? thanks
hi Lisa,
This table shows the difference between all versions of Win 7
Pro/E WF5 should run on all of these. I highly recommend you to get 64 bit version so you can use more than 3 GB RAM.
hi Lisa,
So, pro/e will still work on premium?
