I am using Creo Parametric Release 7.0 and Datecode7.0.7.0
Within the cabling module, wires are losing assigned colors seemingly at random.
The spool colors are designated and the appearances are added to the appearance manager as they should be. (They are auto designated via spool parameters)
May not be random, though I haven't been able to pinpoint a cause. The most recent time this has happened was after modifying the angle of a wiring node location. I was able to change ports on wires without issue.
This has happened multiple times though I haven't found a reliable solution to fix this or a way to avoid it. Any ideas?
