Workspace Best Practices?
andrew1
Guys, I am wondering if you all can weigh in onsome real world best practices for keeping our workspaces from getting corrupted, becoming slow, etc.? I am finding some workspaceshave been used for6 months or longer, whichin my opinioncan cause workspace issues down the road. Here are some thoughts if you have a moment to reply: - How often do you check in or upload your changed models and drawings?- How often do you delete your workspace?- How often (if at all) do youdelete thelocal cacheand let PDMLink rebuild it?- What is your frame stack size set to?- Are you limiting the size of the cache with the config.pro option "dm_cache_limit"? If so, what is your limit?- Any best practices around managing large data sets (5000+ components)?- Any best practices around data sharing (Copy Geom, Merge, Cutout, etc.)? With the July 4 holiday here in the US, there may begood input coming in next week too. I will compile the input and sendit out in a few weeks. Thanks in advance for your contributions. Andy Burkewww.creo-view.com
Hi Andy,
>> upload on every save, checkin when it’s needed for the release or collaboration processes
>> only when the workspace isn’t relevant anymore
- How often (if at all) do you delete the local cache and let PDMLink rebuild it?
>> only when we experience strang behavior for a particular user
>> not activated yet
- Are you limiting the size of the cache with the config.pro<">http://config.pro> option "dm_cache_limit"? If so, what is your limit?
>> not yet
>> the regular PTC best practices (Simpl. Reps etc.)
>> for workspace mgmt.?
We are on Windchill 9.1 M060.
Met vriendelijke groeten, Best Regards,
Hugo.
