X-Section in Wildfire 2.0
Newbie
Good morning,
I'm sure this has been answered a million times.....now, if I had only paid
attention!
I have a full section view set to "No Hidden". When I change it to a
partial section, even though it is set to No Hidden, it behaves as if set to
Hidden in that cosmetic threads now appear when they did not when the view
was a full section. In the View Display dialog, "Hidden line removal for
quilts" is greyed out.
Is there a config I need to set or is this normal behavior?
Regards
Peter Brown
WF 2.0 M060
Re: X-Section in Wildfire 2.0
I should have been a little more specific......when I change the section
from "Full" to "Local" the quilts appear......
"Peter Brown" <-> wrote in message
news:78741@draft...
> Good morning,
> paid attention!
> to Hidden in that cosmetic threads now appear when they did not when the
> view was a full section. In the View Display dialog, "Hidden line removal
> for quilts" is greyed out.
> Regards
> Peter Brown
> WF 2.0 M060
Peter,
That's pretty strange. I don't think there is any difference in the
options that control Local and Full sections.
A simple thing to do first: Make sure that you have updated your drawing
display (View > Update > Current Sheet).
If that does not work, verify that the following drawing options are set
correctly:
- draw_cosms_in_area_xsec = No
- remove_cosms_from_xsecs = Total
- show_quilts_in_total_xsecs = no
- hlr_for_threads = no
Good luck,
Nicolas Hostein
Mechanical Engineer
BioValve Technologies
