a big problem, creo2.0 can't set mapkey in 'F1'
ptc-5688312
7-Bedrock
in proe 5.0 and previous , I can set a maykey in 'F1' .
but creo 2.0 says "can't use F1" . when I press F1 , the help window come out . anyone know how can't I set "F1" as a maykey ???? It is very important to me. Thanks in advance.
Best regards.
Fu from China.
F1 key cannot be used as mapkey initiator, because it is reserved for launching a help. You cannot change this default behaviour of Creo Parametric 2.0.
Martin Hanak
Martin Hanák
thank you . but pro 5, 4, 3 could do that. why proe change to bad. I am so annoyed. you know F1 key is really convienent for a maykey.
Isn't F1 key reserved for help more of a "certified for windows" requirement? Perhaps that's why.
I agree, that is bad. I have had $F1 as datums on/off since '98. Thanks PTC!
Is there a way around this?
Why don't they try to fix the "searching by caps" issue instead of breaking things that work?
::frustrated::
