a compatibility problem
kbenmadhi
Hello everybody
I have a big problem with PTC Creo and it's compatibility with Intel graphics driver
when the driver is installed PTC does not start . When I uninstal the driver PTC starts but it becomes very slow
So please can you help me to solve the problem
thank you all
7 REPLIES 7
BenLoosli
(To:kbenmadhi)
What version of Creo, Student, academic or commercial?
You need to set the following in your config.pro to use the built-in graphics: graphics win_gdi
Creo, and most CAD programs, work best with a dedicated OpenGL graphics card or chip like ones in the Nvidia Qudro series. The Nvidia GeForce series are not certified for CAD applications.
I'm using a student version, and my video card is Radeon not NVidia .
If you search this site you will find that questions about graphics problems most often are from Intel Graphics users. The solution is not to use Intel Graphics. The recommendation was to get an Nvidia Quadro card, and avoid Nvidia GeForce.
Why are you using an Intel Driver with an AMD Radeon card?
Because Intel driver works with the integrated card and the dedicated one with AMD . when I uninstal the intel driver the AMD driver doesn't work .
I will search again for a solution in this site . Thank you all for your advise
I just wanted to inform you that I found a solution to the problem. I searched for a previous version of the intel driver and it works very well .
thank you all
There was an issue reported with the Intel Embedded Graphics card and Creo 2.0.  Please take a look at the following article for further information:
CS156839 - A premature exit can occur when using an Intel Embedded Graphics card with Creo Parametric 2.0
The issue has been resolved in Creo Parametric 2.0 M120.  Prior to M120, you will need to set the config option enable_opengl_fbo to no.
If you need to create an account, to login, do that here.
Amit
