Since the Win11 update, the browser window remains in the background when the option “web_browser_in_separate_window yes” is selected
and can no longer be brought to the foreground by clicking on the icon in the system tray. This affects Chrome and Edge (IE)!
Google returns reponse shown below. I entered creo browser window behind other creo window text.
Note: You can login as different user to find out whether he problem is related to current user profile.
To bring a Creo browser window to the front when it's behind other Creo windows, you can either use the Alt + Tab keys to cycle through open windows, or you can configure Creo to display the browser in a separate window, allowing you to easily manage its position. Alternatively, you might need to adjust display settings or troubleshoot potential conflicts with customized applications or graphics drivers.
Alt + Tab to switch between open Creo windows. 2. Undocking the Browser (Separate Window):
web_browser_in_separate_window configuration option to Yes before starting Creo.
