Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
I would like to do this. Is it a separate license that needs to be purchased? Someone showed me that I could go to Tools/Floating Modules and this would get it to work, but I am not sure if it is the complete package. Any information is helpful.
Pro/CABLE and Pro/PIPING require an additional license requirement (must be bought seprately or within a package higher than the foundation). The question is whether you have it.
when I go to check my system information it is not there, however I can retrive a floating module and then select cabling. i think that we have 1 floating license for this. Thanks
Check your license file for the following strings: # MODULE = Pro/CABLING and # MODULE = Pro/PIPING You should find the info on how many seats you guys have purchased. Best regards! JVidal
