composite datum curve and surface transform in WF 2.0
Newbie
Prousers,
WF 2.0 (preproduction) date code: 2003500
Need to create a composite datum curve (in 2001: insert, datum, curve,
composite, exact) out of three consecutive edges. Menu mapper says:
select the three edges, then Edit, Copy (or use the copy icon). Alas,
edit, copy is dimmed and there is no copy icon. Am I doing something
wrong? Any idea on how to create the curve?
Need to transform a surface or a datum curve (in 2001: feature, create,
surface, transform, move). Menu mapper says: select the surface, then
Edit, Move (or use the move icon). Again, I see no Edit move, no move
icon. Any idea how to perform this operation?
Yoram Schechner
Rafael
