config.pro loadpoint...
nrollins
Greetings,
I am running a different install than I am used to - a corporate controlled
install on their machine. I would really like my mapkeys...
I cannot seem to find the right folder to put config.pro, config.win,
tree.cfg, etc...
Any hints?
Thanks a lot!
Presumably you were provided with a link/shortcut to load ProE. Look at
the Properties of the shortcut, the Start In directory is where you should
put your config files. ProE will load the company standard configs and
then load your ones over the top - therefore be careful that you are not
countermanding specific company standards that could get you into trouble!
Mark von Huben
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
