hot to save my default setting such as units ,density in creo 2.0 , i tried to deal with config .pro but the software did not save my setting
in case of units, density you can set whatever you want in config.pro ... but if you create new parts using template model then Creo ignores config.pro settings and uses information saved in template model. You have to create empty model, if you want to apply config.pro settings.
Martin Hanak
Martin Hanak
