Hi
the problem we are having is when creo 2.0 files are opened in other softwares (cam and cad) the holes end up being cylinders that are split in 2 instead of just holes.
what is the config setting to change in creo 2.0 to change that?
thanks
gary
That how Creo makes circles - always two halves. It's been that way forever and I'm fairly certain you cannot change it.
Thanks Tom
there must be someway to do it. The stamping die divsion of our company uses pro -e (i only use a little) and years ago they had this problem too but found a setting to fix it so things designed in house do not have this problem. Unfortunitly no one remembers what config setting it was.
A few of our other customers that use pro e do have this problem so we want to change the setting to fix the problem as it makes programing these parts with split hole a major PITA
I have no idea why ptc would even have the holes split, what use/ thought idea would that be?
thanks
gary
