creo 4.0 not uninstalling
pallavimeshram
7-Bedrock
I have installed creo 4.0 .
Now it is not uninstalling.
How do I uninstall it?
if you delete installation directory and go to Programs and Features dialog box, you will se Creo 4.0 item. When you deinstall Creo 4.0 item, Windows displays error message and then remove the item.
Martin Hanák
4 REPLIES 4
Just delete the folder.
It may take some work if any of the files are loaded into memory.
Creo does make use of MS registry, so there is nothing that really needs to be uninstalled.
by deleting directly, will control panel -programs and files feature also delete it?
Control Panel\All Control Panel Items\Programs and Features
Martin Hanák
