When my Creo opens ... the Default Wrkpln is, (changed-now> 2d).
How do I RESET it? Thanks...
HI,
Is your query is for Sketcher mode? If yes you can set config option sketcher_starts_in_2d as yes
Are you perhaps using Creo Elements Direct? This area is focused on Creo Parametric and there isn't a default wrkpln in Creo Parametric. The Creo Elements Direct area is here:
