What home page should Creo default to? My config points it to WF5 so every time I open it, it displays WF5/Creo Elements.
I don't know about WF5, but for Creo2 I don't think you need an entry for it to default to. You can probably just comment out the entry in your config file. Creo2 just defaults to a file in the installation directory: i.e. ...\common files\M070\help\usascii\resource_center_index.html
Thanks, I think that's what I'm looking for.
Matt
