Hello fellow users,
I am trying to create a datum curve through points. I select single or multiple rad and array points or single point, doesn't matter since the outcome is always the same. When ProE prompts to enter the radius, it has a minimum of 1.10. I need a radius of 0.5. I know it can be done since it was done on other very similar models where the location of the datum points were the same with respect to common references. I am using Wildfire 2.0 date code M120.
TIA,
Kirk
