datum curve and radius
kklinger
Hello fellow users,
I am trying to create a datum curve through points. I select single or multiple rad and array points or single point, doesn't matter since the outcome is always the same. When ProE prompts to enter the radius, it has a minimum of 1.10. I need a radius of 0.5. I know it can be done since it was done on other very similar models where the location of the datum points were the same with respect to common references. I am using Wildfire 2.0 date code M120.
TIA,
Kirk
After contacting PTC support, the solution was to accept the default radius while creating the datum curve and then go back and edit the curve and change the radius.
Kirk
