Hi guys
Please tell me is there any way to disable rename option in creo 3.0 by config option or is there any other settings by which i can disable rename option of part and assembly
thanks in advance
you cannot disable any Creo command.
MH
I believe that Martin is correct. The only limitation I've seen with the rename command is that if an object is tied to PDMLink, you cannot rename it in Creo outside the PDM environment unless you set "let_proe_rename_pdm_objects" to "yes" in your config file. The default is "no".
