We are using Autodesk Inventor with WGM and for specific requirement we would like to set the dm_checkout_on_the_fly = Continue viz avalialbe with Creo Parametric config.pro. However this prefernce is not available for UWGM > wgmclient.ini.
Anybody knows how to have this on-th-fly message set always to Continue?
Thanks in advance for your help,
-Shashi
Shashi,
Unfortunately, the config option for Creo does not apply to the Windchill Workgroup Manager.
See CS110902 for additional detail.
Craig
Shashi,
Craig
Thanks Craig.
