hi,
In eSupport it won't let me download the PTC CREO 10.0.2.0 files and an advertising window opens that I can't remove.
Why?
thanks
I hope you use https://support.ptc.com/appserver/auth/it/esd/product.jsp?prodFamily=ENG link to display download page.
If you can't see Release Creo 10.0 group then contact you VAR and ask him to update your company records to Creo 10.0.
I took a look and the download page works just like it always has. I've never had an "advertising window" pop up when using eSupport to download Creo software or license files. I would suspect that there is something wrong with your computer? I'd try to download it on someone else's system, too.
Are you trying the download from this page: PTC Software Download - Choose Product Family
today I managed to download creo 10.0.2.0,
the PTC advertising page to switch to the SaaS version is no longer there.
thank you all
