enable to active creo 10 mechanism
DX_9990585
3-Newcomer
having been assembled properly,  the object can move with the drag tab, However, I cannot activate the mechanism tab in the application menu. I participate in the creator program and have a Creo 10 license.
when you click Mechanism button following message appears in message window.
You have to add Mechanism_Design into your psf file.
Martin Hanák
1 REPLY 1
Martin Hanák
