export cabling features as solid in step format
AS_10538336
8-Gravel
I am using Creo Parametric Release 7.0 and Datecode7.0.9.0
I have an assembly with some cabling operations. when I am exporting it as a step file, I get cables as surface but I want it as solid.
it there any way to do so, Please help
Hello AS_10538336,
As Martin mentioned, the behavior you described is the intended behavior with Creo Parametric Cables / Wires.
Cables / Wires display are cosmetic surface representation and not solid features.
You have the possibility to vote for Idea 779705 reporting such enhancement request.
As mentioned by Vivek, feel free to close this discussion if it's ok for you.
best regards
Jean-Claude
I guess this is current Creo functionality. Please ask PTC Support to verify this idea.
Martin Hanák
Hello AS_10538336,
best regards
Jean-Claude
