exporting iges files
rsettle
1-Newbie
Good morning folks, many years ago there was a chart for different settings of iges commands for your config file for different softwares (e.g. SolidWorks, EMS, AutoCad, etc). Is that still around, I've looked and haven't been able to find it. I'm trying to set up a config file to convert PROE drawings to be used in Solid Edge. I had a config file setup from years ago to convert to EMS files, I have used that but have been told that the drawings did OK with the exception of symbols and geotols. Any help or suggestions would be apprecieate.
TIA
Dick
1 REPLY 1
Dick
the file i believe your referring to is dtr121.htm(Suggested Technique for IGES Configuration Options When Transferring Data between Pro/ENGINEER and Specific CAD/CAM Applications) this is still on Search the Knowledge base but hasnt got any entry for SolidEdge files.Will saving your drawing as a Parasolid file inside Wildfire2 work?
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
