we moved to Creo/pro 2 m030(m050) on WC10 m040.
On Wildfire 4.0, in order to add an instance to the family table of say nas620 washers, I woluld check out the generic only, add the needed instance and check generic and that instance back in. It was possible because of the following config options:
save_objects changed
regenerate_read_only_objects no
In Creo/Pro2 M030(or m050) it requires all instances to be checked out and itterated. Why? What is changed?
Did you figure out how to get it back?
Thank you,
D
A couple things we learned when we adopted PDMLink back in 2006. No nested family tables and the check in of the generic has to include every instance.
It was possible to edit the generic or inidividual instances and only check those in but that created a situation where another user could not update their workspace because the other intances were dependant on that workspace generic iteration.
In my opinion treat the entire table as one object. If the generic is checked in and iterated then checkin and iterate all instances too.
KR, Jim
