Greetings all,
It seems that every time I launch Pro/E on my laptop, flexlm is not able to serve a license because "no license file is found". I go to setup and re-point flexlm to the license.dat that resides in the default folder and Pro launches fine... But then, next time, same thing.
WF2 M280, XPP SP3 x32
LMTools 10.8
Any thoughts on this?
thanks
-Nate
Nathan,
Have you tried setting the environment variable LM_LICENSE_FILE to your license file c:\path\license.dat
I used to run several differentprograms that used FlexLM and sometimes they would not run with Pro/E running unless I added the environment variable.
Kenny Mc
