flyouts inside work area
DeanLong
Hey all,
I have been searching the configs and I can't seem to find one that keeps everything within the "window" of Creo. I am thinking of creating some tutorials and theflyouts arenot inside the recording window. Forexample,when creating an extrude and the sketching reference flyout window appears it overlaps and goes outside the Creo window, thus gets cut off in the video.
Can any of you recall the config that forces that to happen?
davehaigh
(To:DeanLong)
I use Camtasia so I don't worry about any of that when I record.
I just record the entire screen. You come back later when editing and pan and zoom where necessary.
Also it then lets you produce the final video at any resolution. So you can do clear down to 640x480 (old standard TV) and by panning and zooming, the users can still read the text and see what your picking on.
David Haigh
Another AutoIT application.
You might either create a script that waits for certain windows to become active or one that moves the currently active window.
I used one that always moved the mapkey window to a second screen and that popped up windows that tended to hide.
x
DeanLong
(To:DeanLong)
Thanks guys.
