generation Clock
Newbie
generation Clock
OK, everybody suggested the config option [CLOCK] [YES]
Thanks for all the replies but that's no quite what I was looking for.
Apparently in SW it works very much like turning echo ON in DOS (I've
not seen it myself), and it gives you quite a bit of detail (at least
how long) about each part as it goes by.
I also go a reply from my local Pro/E rep. The functionality does not
exist in Pro. Enhancement request?
He suggested using geom. check.
Thanks for all the replies!
Martin T. Brown
Spallation Neutron Source
Voice 865-574-4818
Rm# J-319-F CLO
5 REPLIES 5
generation Clock
Date/time stamps are logged in the active trail file during initial
retrieval (but apparently not on subsequent regeneration) ...
Dustin Neifer
General Dynamics Land Systems
"Brown, Martin T." <->
12/12/2007 10:27 AM
Please respond to
To
cc
Subject
[proecad] - RE:generation Clock
Thanks for all the replies but that?s no quite what I was looking for.
Apparently in SW it works very much like turning echo ON in DOS (I?ve not
seen it myself), and it gives you quite a bit of detail (at least how
Martin T. Brown
Voice 865-574-4818
Rm# J-319-F CLO
This is an e-mail from General Dynamics Land Systems. It is for the intended recipient only and may contain confidential and privileged information. No one else may read, print, store, copy, forward or act in reliance on it or its attachments. If you are not the intended recipient, please return this message to the sender and delete the message and any attachments from your computer. Your cooperation is appreciated.
RE: generation Clock
Also not exactly what you want - but may help:
If you open the trail file as text you can see a time stamp for each part's retrieval time - (but not for regeneration).
generation Clock
FWIW - In my (limited) experience with SW, I've never seen such a clock.
It just sits there and chugs away. It doesn't even give the
'regenerating feature 5 or 467' info like Pro|E does in WF.
As I said, my SW experience is limited so maybe I didn't have it turned
on or wasn't paying attention or something.
Doug Schaefer
Doug Schaefer | Engineering Manager
Crow Works
generation Clock
For benchmarking purposes, we used to force some time stamps by adding
to some of our mapkeys, and viewing the trail file, but I don't think
that will help Martin here.
Bob Frindt
Sr. Designer
Parker Hannifin Corporation
Parker Aerospace
Gas Turbine Fuel Systems Division
9200 Tyler Boulevard
Mentor, OH 44060 USA
direct (440) 954-8159
cell: (216) 990-8711
fax: (440) 954-8111
www.parker.com
generation Clock
He's (the rep) just doesn't know. While there may be no functionality now,
there was a spin (a long time ago) where the sweep hand of the clock left
behind colored ghosts every time a part finished regeneration. Or maybe it
was when each started, same difference.
That was at least 10-12 years ago and I only saw it on one spin. I always
thought it was something the developers used but disabled in published
spins, it some how being left in one time.
