I was messing with the view properties and changed my view to perspective. now I'm trying to reset it back to it's original setting and I can't.
I was wondering I it's possible to reset it back to it's original.
In the model or drawing?
In the drawing, once I selected the radio button for perspective all the other radio buttons become under intensified and are un-selectable. Plus you can't un-do.
I can confirm that the problem can be reproduced in CR3 M100 and CR4 F000, too. Please contact PTC Support and report the problem.
MH
in Part or Assembly mode you cannot edit view properties, you have to define view from the scratch.
In Drawing mode, you can edit View properties.
MH
In that sense, Martin, you can restore the perspective view in the model, turn off perspective (render tab), and save the view again.
