I am using Creo Parametric Release 9.0 and Datecode9.0.0.0
My customer want to know how to import rhino model (.3dm) contains attribute user texts into creo and want to access attribute user text properties inside Creo for navigation .
this is not PTC Support. Please use the link marked by red rectangle.
If this so called "Attribut" is something a Creo "Parameter" then parameters cannot be recognized in Creo from Rhino 3D Model.
If it is something else, then pls clarify.
This is not part of Creo functionality.
