i can't install creo 6.0.2.0 (no problem on licensing)
arslankaan2901
3-Visitor
the situation is in the attached picture. visual c++ is okay, a few things you dont see in the picture has been installed before. you dont see them because they are already installed. but anyway, i cant use the program now. i activated the program using student license and there is no error about activation. can you help me to fix it?
A friend of mine suggested me to try out Creo 5 and it worked. Thanks for help anyway. I dont remember what (!) is about, I should have added it. I will handle Creo 5 anyway. Thanks again!
@arslankaan2901
Can you check further details by clicking on information (i) at the end of each application progress bar... ?
What OS were you trying to install Creo 6 on?
PTC stops support at certain releases.
I use Windows 10.
